ordering a strange rear end need advice on gear ratio??
Ok guys i am gonna be ordering my S60 from Strange on Monday but i need advice on what gear to go with im stuck on these three...
3.73's
4.10's
4.30's
these are the mods i have, LT's, ory, typhoon 95mm intake, 95mm tb, 85mm maf, u/d pully, coustom cold air intake, 228r cam, o yea and i have the M6
its some what of a DD but what i wanna know is the 4.30's gonna hurt me at the track or help me put down some better numbers vs the other two
3.73's
4.10's
4.30's
o nice well i still wanna be able to take trips up to cali thats like a 5 hour drive from where im from but other than that its just a lil weekend warrior but i wanna get into the high 11's by the time the cam and rear end gets put in so i was wondering how she would do with the 4.30's over the other two
Restricted User
One thing to consider before ordering this rear is your long term goals. I am now regreting that I chose the S60 due to the limited gear sets that are available. I would very much like the option of a 3.2X or even a 3.0X gear in order to lower my trap RPM. Unfortunately, 3.55 is as close a ratio as you can get so that's what I am stuck with. Other than that, I couldn't be happier with it. I have hundreds of low 1.3 60's on mine and it's the one component that I NEVER worry about when I hang the front tires.
Also, I highly recommend the 35 spline TruTrack posi in it. It feels totally stock. No clunking like associated with a Locker and it's way stronger than the 31 spline version that is available for the 9".
Breaking gears is not an option in this rear end. No matter which gear set he chooses. Being an M6, the 4.30 gear would likely be your best choice. The slower wheel speed will help you launch.
well from what iv heard i don't really have to worry about anything breaking in this rear end especially since i only have around 400hp once the cam goes in
Well with my 4.56 at 70mph the rpm is about 2100 in 6th gear. a little high for a 5 hour drive but not to bad. i would a least do the 4.10s. when i had 4.10s rpms where like 18 to 1900 rpm. but you still get that acceration you want in the first four gears. and mite as well get the 35 splines
