C6 vette...can't downshift from 6th to 5th
Old 05-15-2010, 06:40 PM
turboffr's Avatar
Default C6 vette...can't downshift from 6th to 5th
Well after a few missed 2nd to 3rd's at the track I'm not able to downshift from 6th to 5th. 4th to 5th works fperfectlt ine, no grinding or anything. 6th to 5th feels like it's hitting a wall. It doesn't grind, just won't go in. I swapped out the shifter to a MGW today (great shifter) and while I did that I checked the stock shifter alignment and bushings which checked out ok. Appears my issue is internal, but I'm not sure what the issue is.
Anyone ever have this problem?
Does anyone have an overview on how to remove the tranmission from a vette?
Old 05-15-2010, 08:39 PM
85MikeTPI's Avatar
https://ls1tech.com/forums/manual-tr...s-6th-5th.html
You might want to check over on corvetteforum.com for help on removing the vette trans, if you don't get any help here..
Quick Reply: C6 vette...can't downshift from 6th to 5th
