8.1 BBC LS1 trans swap info
Old 05-16-2010, 12:39 AM
xx_ED_xx's Avatar
Default 8.1 BBC LS1 trans swap info
Lil Background
2004 silverado
swapped 4.3 to an 8.1
been using the 5 speed for awhile now.
Ordered a tick performance 6 spd
Ordered a kiesler shifter relocation which I hope will put the shifter near the stock truck location.
Going to order a Quicktime Bellhousing
Mcleod Dual disc
new slave and reuse factory master.
If i remember correctly there is 2 differnt style ls slaves...
Which one is better and why?
I also vaguely remember something about drilling out the line to the slave for better response. I dont know if the truck has the same problem but i plan on checking. It is the line coming out of the master cylinder correct?
Any info or help would be great thanks
Old 05-16-2010, 12:57 AM
Parasoth's Avatar
For the type of build, I wouldn't settle for anything less than a new Tick MC with their stainless line. More flow, better shifts.
Old 05-16-2010, 01:01 AM
xx_ED_xx's Avatar
uh this is a silverado, My line is stainless braided from the mc to the slave stock
Old 05-16-2010, 01:02 AM
Parasoth's Avatar
And theirs is bigger.
Originally Posted by MeentSS02
The last time I did a clutch swap (2006 I think), I noticed that they had done a redesign of the slave. The one I put in back then looks like your new one does now, and has been fine to this day.
From a thread not too long ago.
Old 05-16-2010, 01:19 AM
xx_ED_xx's Avatar
Where is this master cylinder you speak of?
Old 05-16-2010, 01:48 AM
xx_ED_xx's Avatar
Ok the thread you was quoting from was the slave cylinder. So an ls6 one or new redesigned ls1 one
