Convertible Vehicles - Top motor
jhny777
05-16-2010, 08:44 AM
When car was purchased top motor was just sitting in the trunk not bolted down.
Top will go down but not up.
Rebolted motor back in.Operated fine for a day.Then stopped.
Figured was ground so grounded the motor with a ground wire!
Still no workie.
so the question is where is the factory ground for the switch as the motor
has only two wires entering the motor!
Thanks for any help>:bang:
GR8RYD
05-18-2010, 03:04 PM
No personal experience but I think it works this way. The motor has only two wires because the top up/down switch reverses the polarity of the 12 volts going to the motor and thus, reverses the direction the motor runs. I think I would be looking at your switch for the source of the problem. Good luck! Tom
00Camary
05-20-2010, 11:24 AM
I have a extra pump motor if need be. :)
JohnnyBs98WS6Rag
05-20-2010, 12:19 PM
If the motor works in one direction, it'll work in the other.
Sounds like your switch may be bad, not an uncommon occurance. The switch connects through the console harness, ground and power, I believe, come from under the dash. Like GR8RYD said, the switch reverses the polarity on the 2 motor wires. If the motor works in one direction, the ground and power connections to the switch are good and all the wiring is good. It's most likely bad switch contacts for the reverse direction.
c-dub
06-13-2010, 08:52 PM
Hmm well my motor puts the top down, but when trying to go back up it goes "wrrrrm" and stops haha it just gives up...any suggestions?
eseibel67
06-14-2010, 05:18 AM
If it trying, it's not the switch.
Probably a hydraulic problem. It takes more effort to raise the top than power it. Check the fluid first.
c-dub
06-15-2010, 06:13 PM
ok fluid has been checked, looks a little low, how to fix? I looked up the sticky thread but it wasn't very informative other than."buy fluid, fill up" this is not the kind of thing I want to jack up? any helpfull tips?
JohnnyBs98WS6Rag
06-17-2010, 08:25 AM
Top of the pump resevoir is a plug w/ a hex head. Remove that and fill w/ mineral oil up to between the double lines molded into the opaque resevoir. Replace plug, cycle the top up/down a few times to purge air. Recheck level and top off if required.
c-dub
06-17-2010, 01:06 PM
mineral oil? haha where can I find that, or is that in afforementioned 5 gallon jug?
JohnnyBs98WS6Rag
06-17-2010, 02:15 PM
Yeah, updated recommendation from GM. (Wierd, I know) You'll find it cheap in any Pharmacy (in the laxatives aisle).
c-dub
06-17-2010, 04:17 PM
would you happen to have a link to that info? lol NO offense intended but that sounds kinda like bum scoop because it's so random.
JohnnyBs98WS6Rag
06-18-2010, 10:41 AM
Another thread (http://www.ls1tech.com/forums/12190559-post6.html)talks about this. Here's another thread (http://www.ls1tech.com/forums/convertible-vehicles/413665-question-about-hydraulic-fluid.html)that goes back a ways. I've had mineral oil in my system for over 8 years, no problems w/ it. So have many others.
GR8RYD
06-18-2010, 12:55 PM
Johnny speaks the truth..:cheers:
c-dub
06-20-2010, 02:54 PM
I appreciate the info, very helpfull :)
