SigmaX6
05-16-2010, 04:02 PM
So alil back story in-case this has anything to do with the current issue.
Couple days back I had a new catless DP installed cause I broke the flex pipe. My old catless DP was stock size with no cat. My new one is 3inch (with a 02 bung) all the way back till where the res used to be and then goes back to stock size with aftermarket mufflers. The car pulls a lot better up top now :)
So a couple days after I had all this done I went to turn on my car via command start and the cars fog lights just kept blinking at me. So no biggie I walk up and turn it on manually. Then about half way to work I get a a CEL. So I stop off at a friends and scan it with a OBDII reader and no codes are found. So at work I disco the battery and the CEL goes away.
Half way home the CEL turns back on. Command start still not working.
Drove down to my uncles shop and hooked it up to a tech2 and he couldn't find any codes....
sorry for being long winded and thnks if anyone has a clue wth is going on haha!
