Custom painted FAST pics
Pics of a custom painted FAST I just finished. It's Lemans Blue from a C6 Corvette with silver accents.
"Smoothing takes some time. For the FAST, I usually start with a 80 grit to remove rough texture, then follow behind with 180 to remove the fuzz from the 80. Follow that with a plastic primer, let dry overnight and then hit it with 320 before spraying."
Is this the process you used that you posted in this thread? https://ls1tech.com/forums/appearanc...intakes-3.html
