700r4 to th350
700r4 to th350
I've been thinking about swapping out my 700r4 with a th350. Do these transmissions use the same torque convertor or will i have to get another. I was told that the spline is different. Thanks for any help.
First, you will need to install a 350 non lock-up converter. Other than the converter, there IS a kit for this conversion that comes with a correct length output shaft, a tailshaft housing spacer (you use the 700-r4 tailshaft housing), correct filler tube, detent cable and even new selector indicator decals, PM me for details!
