8100 Avalanche engine in 78 Suburban
Old 05-19-2010, 03:34 AM
jw usa's Avatar
Default 8100 Avalanche engine in 78 Suburban
Is there someone who knows what I need for a complete engine swap for my '78 Sub. I want to replace the 7400 for a 2002 Avanalanche 8100 engine.
I saw I needen the ECU, gaspedal, wiring harness complete engine.
Do I also need the ignition key and so on?
I hope someone knows over here!
Thanks,
John, Holland
Old 05-19-2010, 04:51 AM
davidws6's Avatar
It would be easier to obtain a complete setup, Engine, and all accessories from it. Or you could get a custom harness done eliminating some of the things you won't need on your 78.
Old 05-19-2010, 04:57 AM
jw usa's Avatar
I saw this engine on E-bay, is there something more I need?
http://cgi.ebay.com/ebaymotors/4-8-5...Q5fAccessories
Old 05-19-2010, 07:34 AM
Jim85IROC's Avatar
http://67-72chevytrucks.com/vboard
There are a couple guys in the 73-87 forum that have done this swap.
Old 05-19-2010, 07:54 AM
jw usa's Avatar
Do you have a link?
Old 05-19-2010, 10:34 AM
Jim85IROC's Avatar
I linked you to the forum. They have a very good search feature.
Old 05-19-2010, 12:56 PM
jw usa's Avatar
Ok, I found it!
Thanks!
Old 05-19-2010, 04:38 PM
Pocket's Avatar
Wiring those BBCs is nearly identical to LS1s. They use a crank and cam sensor comparable to the LSx along with the LSx individual coil packs
Old 05-19-2010, 07:51 PM
deuce4935's Avatar
And you can also swap the dbw tb for a f-body cable tb and not have to worry about the pedal setup. Also, depending on how close you are to Chgo, I have a complete engine minus harness and pcm with 60,000 miles foe sell.
Old 05-20-2010, 12:58 AM
jw usa's Avatar
So I don't need the key and lock because of a start block mechanism?
Old 05-20-2010, 09:24 AM
deuce4935's Avatar
No, just be sure to have the vats deleted from the pcm you will be using.
Old 05-20-2010, 09:37 AM
jw usa's Avatar
What do VATS mean?
Old 05-20-2010, 09:51 AM
thedrill's Avatar
Default vats
Vehicle Anti Theft System
Or Very 'ard to steal
Old 05-20-2010, 03:32 PM
jw usa's Avatar
Ok, how can I arrange this? There are no dealers around here. Is it possible to send the computer to a dealer or something?
I am really glad you all answer to my questions!
Old 05-20-2010, 04:00 PM
deuce4935's Avatar
wait4meperformance.com can get you straightened out, ask for Jesse.
Quick Reply: 8100 Avalanche engine in 78 Suburban
