Spec 3+ / fidenza FW = vibration at 1st gear
Hi
I installed spec 3+ / fidenza FW and there is some vibration on 1st gear is it normal or bad installing ?
The rest gears shift very smooth
I'm only doing 20 miles on it until now
Sounds like its just clutch chatter. I would say that's pretty common on break-in of a new clutch. The 3+ is a full face so I wouldn't think it would chatter but then again my twin disc is also full face and it chattered a little bit for the first 30 or so miles. I would think that if it is chatter that it will go away completely as you get some more break-in miles done.
A little chatter is common when leaving from a stopped position in first or reverse with little mileage on the clutch. Complete the break-in process and it should smooth out. Feel free to contact me with any questions you may have. Thanks!
