Synchro assembly question
Old 05-21-2010, 11:06 AM
iowackers's Avatar
Default Synchro assembly question
I am installing the billet keys and updated springs on my new synchros and I have a question about spring orientation. The service manual says to locate the spring tab on the same key, but run the springs opposite directions on each side. A T56 rebuild write-up on here says to orient them the same direction on both sides. Which is correct or does it matter?
Scott
Old 05-21-2010, 02:44 PM
iowackers's Avatar
Any suggestions?
Scott
Old 05-21-2010, 08:18 PM
greatskiiiier's Avatar
id trust the service manual first, but give tick or some other company a call, they do it everyday and they'll know best
Old 05-21-2010, 08:24 PM
jmd
jmd's Avatar
Look at the flat face of the synchro as if you're at the front of the car. Start at 12:00 and go clockwise. Rotate the assy. on a vertical axis & do the same.
This begins the springs at the same key but they go in opposite directions away from the key.
Old 05-21-2010, 08:36 PM
bww3588's Avatar
same key, different direction. this is basic manual tranny 101, same for all manual transmissions.
Old 05-22-2010, 06:52 AM
99ssleeper's Avatar
same key, wind opposite directions.
also, youll read that the lines on the synchro rings should all point forward. mine, from the factory, pointed rearward. it makes no difference which way the synchro faces. just incase you have a question about it later on...
Old 05-24-2010, 09:19 AM
iowackers's Avatar
Good. I went with the service manual and how they were when I disassembled. Same key, wind opposite direction. Thanks for the input.
Quick Reply: Synchro assembly question
