factory chrome wheels wont hold air
yes they are 100% straight with no curb rash or bends, the chrome is peeling inside the rim on the beadlock. discount scrubbed it with a wire brush and got rid of the peeling chrome but the wheel still wont hold air for more than a day or two without going flat.
anyone know how to fix this problem? or do i need to find a place to buy one stock t/a wheel?
seems like a minor problem to have to replace the entire wheel, but discount has no other ideas?
hey man i worked in a tire shop for 2 years. they need to sand it using an air tool. the sanding disc is like 3 inchs in diameter. then you use some beadseal and use the brush inside the can to put some on the bead of the rim. let it dry then mount the tire. put money on it that will work.
