Advanced Engineering Tech - Quick question on LS1 head design
Firebirdfan
05-21-2010, 04:39 PM
So, I currently own a 93 5.0 Mustang (my first "performance" car) and in doing so, I've found my way to a few mustang forums. One of the more resourceful ones I've come to is corral.net. Now, this forum is full of some really good info, but a lot of the guys seem to be older (30s-40s) and completely against everything Chevy has ever done, most notably though, the LT1 and LSx motors.
One of the things I keep on reading is that Chevy "stole" the head design from Ford because they were too stupid to make it themselves. Now, I've got a few LS1 books and from what I've read, the head design, as well as the rest of the engine, was a totally clean-sheet design. However, I don't know if LS1 heads will bolt up to a Ford motor or not. Is there any truth to this? Anyone heard of this "arguement" before?
garygnu
05-21-2010, 05:08 PM
no the head will not bolt on.they are refer to the port arangement.gen 1 sbc had siamesed intake ports,and the center exhaust ports were siamesed.the old ford heads have spread ports intake and exhaust.
Old SStroker
05-21-2010, 07:46 PM
You made us 60-70 year old guys ROFL. I'm a 1943 vintage.
You might tell them that a quick, inexpensive way to make a Mustang fast is bolt in an LS1. The Ford headers can be made to fit. It's not that GM copied Ford, they just wanted to make the swap easier so Ford guys could experience some serious performance.:)
OK, serious question: anyone know why the Gen III Ls head has the "cathedral " ports?
Jon
garygnu
05-21-2010, 08:40 PM
injector spray.Jon check out the thread on E-85,what are you thoughts?
Firebirdfan
05-21-2010, 10:03 PM
I know exactly what you're talking about. Might have to go stir up some dust in that thread. I'm tired of reading all the LS1 bashing on that forum. It gets a little old.
Old SStroker
05-24-2010, 12:08 PM
Nope, not from what I hear. That was a secondary result, even though that was the first thing everyone (perhaps including GM) said in '97.
It has much more to do with making power, increasing durability and lowering cost. More power, longer life (and maybe higher rpm capabilities) and less cost...imagine that! Just like with OHC engines, right? :)
Hint: Look at the differences in LS7 & L92 vs. the cath. port head assemblies.
OK, another LS question: Why the "D" shaped openings in the caps over the ends of the LS rocker arm trunnion bearings? This is easier.
Also, why are these "Ds" not used in the Comp or other LS trunnion/bearing conversions?
Jon
PS: Please link me to the E85 thread you mentioned.
Stang's Bane
05-24-2010, 12:22 PM
Pushrod location for the cathedral ports
I will hazard a guess on the D-shaped question. Is to keep them from being put on upside down. Much quicker on the assembly with not having to look and see if the trunion is countersunk on the side you want to use.
As far as them not being on the aftermarket kits, maybe at the upper limits they could possibly limit the travel on the rockers?? Need to sit down and look at a stock rocker....
Old SStroker
05-24-2010, 12:37 PM
Correctamundo!
There was an old saying in the OEM business: "If it can be put together wrong...it will be!" One OEM had a headbolt pattern that let you index the head one cylinder off (three covered and one uncovered on a V8 bank). The locating dowel fit into the combustion chamber. One engine came down the line with the off-indexed head torqued in place.
The aftermarket assumes folks will look at the round side vs the flat/c'sunk side of a trunnion and install it correctly. Oops, not so fast. I did see a thread where a guy tried to install a rebearinged LS rocker round side up.
Reminds me of the old landscape joke: "Green side up."
Jon
KW4life06
05-25-2010, 04:10 PM
these are interesting factoids. Subscribed haha. So why did they quit using the cathedral port?
bww3588
06-01-2010, 08:54 AM
the GEN I and II heads will not bolt on, but....the LS heads WILL bolt on to a SBF. now it wont work, but it will bolt up.
the story i got from one of my instructors who used to be in tight with Ford's engine department, told me that 3 ford engineers left and went to GM and helped design the GEN III articheture. i didnt beleive him when he told me it would bolt up, but we had a 302 block and a set of LS heads laying around the shop and sure enough they bolted right up.
Old SStroker
06-02-2010, 12:34 AM
That might make a couple of GM guys named Sperry laugh. ;)
Last I heard the vast majority of LS engines still use the cathedral port head.
Jon
bww3588
06-02-2010, 07:33 AM
Jon
never said they didnt use the cathedral port heads, the point was, they will bolt up to the block.
rsz288
06-02-2010, 07:40 AM
Jon
Production car engines?
Old SStroker
06-02-2010, 02:13 PM
The VAST majority of all LS engines built to date are not "car" engines, but rather truck and SUV engines...but you knew that.
There is no way an OEM could/would design, develop and tool up (for about 3/4 billion $) the relatively inexpensive to buy LS engine in order to build only about 35,000 engines annually (after old F-body and before 2010 Camaro). OK, with the Camaro it might be double that this year. It's the nearly million or at least high hundred-thousands of truck LS engines per year that made it affordable, and will continue to do so. The majority of them (4.8L & 5.3L) have cathedral port heads.
I don't think it strange that variants of the LS family do a good job slugging around Silverado work trucks as well as CTS-V Cadillacs and ZR1 Vettes. Our favorite "car" engines are really truck engines wearing some better underwear.
My $.02
Jon
bww3588
06-02-2010, 02:23 PM
How do you figure they are truck truck engines when the ls family was originally designed for the f and y bodies?
Old SStroker
06-02-2010, 07:47 PM
It would be nice if that were true. Nope, the LS was designed to go into the largest use of V8 power in GM....trucks. It could also be used in Y & F,etc CARS also. A good design is a good design no matter what it is put into. Cars got aluminum blocks and pretty intake manifolds, but the fugly 90mm truck manifold is better for power than the LS6 in some applications.
I suspect we'll be seeing many more LS truck engines with aluminum blocks.
A used 6.0L truck engine makes a hell of a basis for a 155 mph 8.50 bracket dragster. Stock bottom end (with better rod bolts), mildly reworked 5.3 heads, single plane carb intake with a 4-bbl throttle body, stock lifters and rocker arms, a hydraulic cam, good springs and pushrods...result is 7900 every run. They could call the engine a GMC and not be wrong.
Corvette got the initial LS1 for a number of reasons:
The C5 needed a new engine. It was exclusive for a year or two. Great image builder for the car AND the LS (Gen III).
It was easier to start building engines slowly and then increase capacity by tooling additional engine plants. It also helps work out the build and assembly bugs.
Adding the F-car increased production by 100-200%, but adding the trucks increased it 10-20 times.
Sorry to burst your bubble.
Jon
ChucksZ06
06-02-2010, 07:58 PM
Very true about the engines being built to work well in the trucks...because of the volume needed. GM uses the vette for test bed on small volume. LS engines, then ETC, Aluminum blocks, etc. You watch, the direct injection will come in the vette and then become available in the trucks in a year or two. I have no afiliation with GM, but the pattern is easy to see.
01ssreda4
06-03-2010, 02:10 PM
About 12K ls1s a year in the final years of f body production, meanwhile 100k+ trucks a year. Business is business. The world doesnt revolve around f bodies.
Old SStroker
06-04-2010, 08:12 AM
In 2007 GM sold over 2.5 million Chevy and GMC trucks. They all weren't Gen III, Gen IV engines, of course. At 1.5 million, that's 15 times 100,000. We are talking lots of engines!
Jon
01ssreda4
06-04-2010, 12:26 PM
^^^i was specifically referring to fullsize trucks. Whats the combined sales numbers for chevy/gmc trucks with gasoline small block engines? Gotta be in the neighborhood of 100-300K I assume, all of which should have the gen 3/4 architecture. Sorry I dont keep up with truck engine options.
Old SStroker
06-04-2010, 04:19 PM
OK, I'll try again. Sorry if I was confusing.
2007 Chevy truck sales 1,960,000
2007 GMC truck sales 615,000
Chevrolet plus GMC = 2,575,000 or just a tad (75,000) over 2.5 million
I estimated 1,000,000 of those were not full size trucks or had diesel engines. (I was being conservative.) That left 1,500,000 full size trucks with Gen III or Gen IV engines.
1,500,000 / 12 months is 125,000 per month or over 4000 per day if you sell 7 days a week. Few dealers do.
That's still a heck of a lot more than 100-300K annually. It's actually 5 to 15 times as many.
OK, let's say that TOTAL Gen III Gen IV engine production from 1997 to date is over 15,000,000 (15 million). I heard 17 mil recently, but I can't find the reference. Producing that many engines is hard to imagine unless you have visited/worked in an OEM engine plant. If a plant can produce 100 complete engines an hour, it would take 15,000 hours to make the 1.5 million. At roughly 2000 working hours per 40 hour week in a year, that's 7-1/2 40-hour shifts evey week. It takes at least a couple of engine plants to do that.
We are into the 13th year of the C5-C6 (Gen III, Gen IV) era. At 30,000 Vettes per year, that's 390,000 or just over 3 months normal truck sales of these engines. Being generous with Camaro and TransAm 1998-2002 sales, that might amount to maybe 100,000-125,000 more engines, about one month's production.
So if you like numbers, 4% of all Gen III & Gen IV engines have gone into cars and 96% into trucks. My guess that is pretty close to the plan when the Gen III was conceived in the early-mid 1990s.
My highly-opinionated $.02
Jon
garygnu
06-05-2010, 11:07 PM
thank you very much JON for your input on many subjects posted here ,I learn alot from your response to all the question on this forum.
joecar
06-06-2010, 03:47 AM
With the non-cathedral port heads (mentioned above), how much of a compromise is the offset rocker arm...?
The force/torque on the rocker arm is now not contained within a single plane, how does this affect durability, and are any special considerations required...?
