I Swapped my 06 5.3L for a 98 LS1 Flex Plate Question
Old 05-22-2010, 12:03 AM
LS1_MK2_Supra's Avatar
Exclamation I Swapped my 06 5.3L for a 98 LS1 Flex Plate Question
I put a built 98 block LS1 in my 2006 L59 5.3L Tahoe. My question is.. Is the flex-plate mounting depth on the crank different? Right now there is just under a half inch gap between the converter and the flex-plate. I did also put in a stall converter, and am not sure if it is the conveter that is causing the issue, but I doubt it. Any ideas?.. will add a pic soon. Thanks
Old 05-22-2010, 12:09 AM
racer77ss's Avatar
did you turn the converter tell the notches slid on the pump
Old 05-22-2010, 12:14 AM
Yes, the converter is all the way on. I think you are thinking the opposite. Here is a pic..
Old 05-22-2010, 12:25 AM
racer77ss's Avatar
i c idk maybe it is different but i wouldnt think so? what trans does it have? what stall is it?
Old 05-22-2010, 12:45 AM
2800 Stall, 4L60E
Old 05-22-2010, 11:57 AM
somedude's Avatar
I think you could probably put washers in there to make up for the gap. I am not sure If I would want to pull the converter any further away from the transmission than you need to.
Old 05-23-2010, 09:00 AM
Bump. Any Help???? I'm about to just fill the gap with washers as wrong as that seems to me. I can not come up with a reason as to why this is like this. The LS1 block is the same as the 5.3 block right? Maybe the converter is wrong, I guess I'll find out. Any help would be great. Thanks guys.
Old 05-23-2010, 07:56 PM
11 Second Truck Club
MPFD's Avatar
which way is the dish on the flex plate facing? The belled side should face the trans... Just a thought? Who made the converter?
Old 05-23-2010, 11:31 PM
Plate is on the same way it came off.
Old 05-24-2010, 12:33 PM
MPFD's Avatar
So which way is the dish facing? Which motor did it come off of the 5.3 or the LS1?
Old 05-24-2010, 01:14 PM
It came off the 5.3 and the dish is facing the right way. I called a friend of mine that is a GM tech and he said that gap is normal and the bolts are of to just pull the converter to the flexplate. Now I just started the motor and have no oil pressure. Gotta pull the front cover and see if I can check the o-ring. ugh.
Quick Reply: I Swapped my 06 5.3L for a 98 LS1 Flex Plate Question
