Installing LT's tomorrow...are all my bases covered?
I've read instructions, some more vague than others but it is what it is.
Existing:
2002 Z-28
SLP Loudmouth I cat back
Going on the car:
Pacesetter coated long tubes, TSP ORY
I bought:
GM metal exhaust gaskets
O2 extensions
header bolt kit (came with headers)
all necessary clamps
I will be putting the car on a lift, and will have access to an air compressor. I know I can remove the steering knuckle and mess around with raising/lowering the engine a tad...
Any other "gotchas" I'm missing that could save me some headaches tomorrow? Maybe my google-fu sucks, but I haven't had too much success finding specific "how to's" other than the obvious.
Thanks!
Existing:
2002 Z-28
Going on the car:
I bought:
O2 extensions
Thanks!
If I were you, I would do motor mounts. Thats what I'm doing when I get started with my Headers and ORY (soon). I don't want to take the risk of the Y pipe Banging and I dont want my engine to shake to death and lose torque over that. Prothane's are what I have in a box right now.
You can also get spark plugs and wires. That would be great, unless you just changed them. If you haven't gotten any then get TR-55 if you plan on staying N/A or of you plan on using a power adder then use T-6's and MSD Plug wires.
Exactly. Do them now while its "easier" when the headers are off then doing them another time later. Do it once and forget it. The Prothane poly's are $50 dollars with everything included. If you want to go crazy then you can get Solids for $150 but if its a street car then you can stay with poly's.
Having finally finished my Poly MM + Headers/Y last night, Im gonna post a new comprehensive writeup with lots of pics of MM and Headers/Y install this weekend. Luna, I believe, wrote a "Best Poly MM writup Ever" thread that was my Bible this past week, but I needed pics, so I took as many as I could.
I did not have to remove anything steering related when I did my pacesetters. On the drives side I had to grind a little of the tab on the back of the block and they slid in. Passenger side I had to move starter out of the way..
I did replace motor mounts and glad I did since one was starting to tear.
Don
Don
The passenger side slipped right in for me effortlessly. The driver's side required removing the steering linkage, but it only took about 10 minutes to remove and reinstall. Hopefully all the hard work will be worth it once I get it tuned properly...
I'd say the total time spend on the install was probably 12 hours over two days. Had to do some Y pipe modification to get everything to line up properly with my catback.
I'm in the "Do the Motor Mounts NOW While the Exhaust is Outta the Way" category.
Just know this: If you choose not to do the mounts now and you do end up with a banging Y-pipe, you will have to completely remove your new Headers & Y, in order to get to the mounts so they can be upgraded.
Good luck with your install.
[/QUOTE]I'd say the total time spend on the install was probably 12 hours over two days. Had to do some Y pipe modification to get everything to line up properly with my catback.[/QUOTE]
What mod did you do to your Y-pipe to make things line back up?
Don
Don
I trimmed about two inches total from two pipes on the drivers side of the y pipe because no matter how far i pushed the y pieces together and onto the collectors, the drivers side was too long and it prevented me from pushing the catback far enough forward to be on the exhaust hangers. Aside from that it fit pretty good as far as clearane under the car is concerned.
https://ls1tech.com/forums/generatio...otsa-pics.html
