TSP True Duals Installed w/ Suspension- Pics!
Hello Everyone,
We just installed a TSP true dual system and Pacesetter LT's with our transmission mounted torque arm, torque arm relocation kit and 3-Point SFC's. The fit and clearance of all items together is great and there were no issues. The torque arm was originally designed around the TSP duals, so when you install the TSP duals with this torque arm it actually allows you to tuck exhaust system up tighter than the stock torque arm allows. This is very nice due to ground clearance issues.
Please enjoy the pictures and let me know if you have any questions regarding the set up.
TSP True duals w/ UMI full suspension
Thank you,
Ryan
Thank you,
Ryan
I'll be using that TA and relocation kit from you guys very soon. This along with your rear drag sway bar and a k-member and I'll be done with the underside of my car and using all UMI pieces.
LS1Tech Premium Sponsor
Very nice, Ryan! Thanks for sharing that info!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
