LS4 Performance - kyb struts
View Full Version : kyb struts
monte_with_a_LS4
05-22-2010, 10:58 PM
wheres the best place to buy them with the best service and best price. any help would be great. Thanks!!!
94ss06gxp
05-23-2010, 06:52 AM
i would say summitracing but IMO i wouldn't recommend Keep You Bouncing shocks or struts, i would go with Bilstiens.
monte_with_a_LS4
05-23-2010, 07:21 AM
well im planning on purchasing ssc springs and i want to do it right and replace the struts too.
94ss06gxp
05-23-2010, 07:37 AM
yeah man im saying replace the struts but i am not a fan of KYB, neither is alot of people i know, just recomending different brands.
06 SS
05-23-2010, 07:43 AM
I had great luck running them on my XJS. Heavy car and zero problems.
The Guz
05-25-2010, 08:06 PM
Look into getting some bilsteins from a GXP. Morad parts often sells them. They seem to handle a lowering spring faily well. If you are going with standard KYB's then don't expect too much from them. They don't handle a lowering spring well and can wear out pretty quick. I lowered my 99 grand prix and got maybe 10K miles on KYB GR2's.
You can also do KYB AGX's from a previous generation wbody. You would need the sway bar endlinks and lower control arms. This gets a little pricey.
monte_with_a_LS4
05-25-2010, 08:36 PM
damn this sucks. i was hoping to only spend a little over $500 on suspension not including what the stb bars are going to cost. That is pretty much going to be my suspension. Im just wanting some struts that i can get a good amount of mileage out of that wont run me too much
RickAKATed10
05-26-2010, 12:43 PM
Well how much are the Bilsteins?
Neanderthal
05-26-2010, 03:53 PM
Good luck. Good parts cost good bucks.
I had some KYB GR2 installed on my Impala base.
While far better than the stock, 0W-05 soup-filled struts, they are not high performance struts by any stretch of the imagination.
One rear Bilstein cost me about $215 + $47 shipping from GM Parts Direct.
The Guz
05-26-2010, 04:09 PM
Contact Morad parts. They are popular amongst the wbody crowd. PM Me if you need there info. They may have some low mileage bilsteins.
LS1 Racing
05-26-2010, 06:35 PM
Yeah, the GR2s are meant to be stock replacements. I think it's the Gas Adjust line that is considered for performance.
BuffaloSS
05-27-2010, 10:02 AM
NOOOOOOOOO!!!!!! Do not install KYB struts on an Impala or MCSS. They're not designed correctly and they will rub the shit out of your tires. The rears are considerably worse than the fronts.
KYB supposedly redesigned their struts (raised the spring perch) to accomodate this issue with the FE3/FE4 performance suspension, but it's still not right, since even their new version will touch the tire. Clearance with the original GR-2's while sitting is fine...you have about a finger's thickness with stock wheels...but as the tire gets hot and expands, it will rub. The AGX (performance adjustable) is no different.
If I can find the pics of mine, I'll show you the damage. I have GR-2's and SSC springs installed right now, but plan to replace the struts as soon as I can.
monte_with_a_LS4
05-27-2010, 09:37 PM
will the shocks off the gxp fit fine on the monte carlos? anyone know?
BuffaloSS
05-28-2010, 07:44 AM
I don't believe anyone at LS1 or NAIOA have spent the money on the Bilsteins...but it's truly hit or miss until someone installs them and after 10k reports back with no issues. The GR2's were supposed to fit every w-body with the exception of the police & taxi packages, yet they don't...so until there is a tried & true remedy, I'm going to have to run stock.
The major issue is, again, the spring perch. If someone were to re-drill the mounting holes (if that's even able to be done safely), I suppose you could remount the strut and have the plate sit the 1/2" higher it needs to be. I haven't looked at the setup in the rear recently, but when I take off the tires for my next _______ repair, I'll see if I can do this and save the time/$$ that will need to be invested to reinstall the OE struts.
BuffaloSS
05-28-2010, 07:51 AM
These are the new Excel-G's that are supposed to fit...
http://www.showmetheparts.com/BIN/images/KYB/339148.jpg
And these are the ones that don't...
http://www.showmetheparts.com/BIN/images/KYB/334228.jpg
It doesn't look like there is enough room to re-drill the holes as needed for the 1/2" clearance we need. I suppose that you could elongate the holes to get close, but what (besides a shit-load of torque) is going to keep the weight of the car from blowing the knuckle/assembly right back up to the original resting spot?
Typically, for alignment purposes, they do this but it's a side-to-side adjustment, not up & down.
The Guz
05-28-2010, 03:41 PM
They will bolt up just fine.
monte_with_a_LS4
05-28-2010, 08:34 PM
whats a link for those. and they will bolt up just fine with no drilling? just dont want it to be a pain in the ass
monte_with_a_LS4
05-29-2010, 08:28 PM
anyone know???
