jasonk
05-23-2010, 07:38 PM
Alright I just got done installing an ported Fast 90 setup with an LS2 Throttle body, and have come across some issues, I cannot get the car tuned until Tuesday, however it is going to be tuned. What I am trying to figure out/ make sure of is that the current issues I am having are going to be able to be fixed by tuning, and not something that I will find out later to be an actual install problem. Here are some details
I have a small cam done 224/226-114, and since the cam install have had startup issues (tuning problems, just wasnt willing to pay lots of money to fix it until I had done the fast 90)
Fast is ported by Vengeance Racing, and done right,
Stock Fuel Rails
Newly Installed Summit 30lb fuel injectors (should run like redtops at our fuel pressure)
Replaced valley cover bolts with accurate button head allen bolts
LS6-LS2 TB wiring adapter
Now the issue, I cannot idle what-so-ever without the help of my right foot, I want to make sure this is a tuning issue and not a leaking issue, or failed injector issue. The car originally went into limp mode, and i followed the throttle relearn instructions, and it hasnt gone back yet, it seems to sound ok when throttle is applied.
I am under the impression that I should not have to drill holes in the TB plate with the DBW setup, but maybe.
Anyone with experience I would love to hear about it, or things to expect
Thanks
Stock Fuel Rails
Thanks
