3.23 Gears and Engine RPM
I got my 98 about 2200-2400 RPM and at 55 RPM is right below 2000 RPM.
Now I know my 3.4 had 3.23s and at 70mph it did 2100RPM, I know my LS1 is a completely different engine but I figured it would be about the same.
I also don't feel the converter locking up, is there that much slippage?
It is a 98 LS1 Auto w/3.23s just to make sure y'all have the right info, ohh and it's all stock.
try it both ways,shouldn't make a difference in tach readings.
also,from a stop,accelerate very mildly(just above idle but enough to accelerate),you should feel and see(tach)the 1st to second shift,same with 2nd to 3rd,same with 3rd to 4th,once in 4th,and after the 3/4 shift, a couple hundred drop in tach rpm indicates lockup.
Alright I tried the start from a stop and slow accelerate, and sometimes I THINK it MIGHT have lock-up, but others it didn't. I even tried going 55 and hitting the brake while giving gas to see if it would unlock, and no dice. I'm thinking I have no lock-up.
