How can i make this alternator work?
I have a '91 s10 and i am trying to make an alternator work thats from a '99 blazer. The blazer alternator had just one single red wire in the plug. My factory '91 s10 plug has a brown wire and a pink with brown stripe wire. How do i make this work.
http://http://www.madelectrical.com/...hreewire.shtmlHere is a pretty decent article that explains the how's and why's. Hope this will help you out a little, or at least get you going in the right direction.
Look at the connector, the wire in pin "B" goes to the light, the service manual says it should be red, it doesn't list another wire. I looked in both 98 and 99, they're the same
Looking at your picture, there is a notch in the plug where it goes in to the alt, the wire next to it is "B"
