Gen 5 Camaro Drivetrain Tech - 3.73s for da 2010 ss?
View Full Version : 3.73s for da 2010 ss?
rouchiemanz28
05-26-2010, 02:12 AM
Has anyone heard or know if there is a 3.73 gear for the 2010 ss? These cars are just begging for them!!!!!!!!!!!!:lock:
rayhawk
05-26-2010, 07:07 AM
There is a 3.73 and a 4.10 available, but they aren't cheap. Do you have an A6 or a M6? The M6 comes with a 3.45 from the factory, so I'm thinking 3.73's would not be worth the trouble. The A6 however comes with 3.27's, so 3.73's would be about right.
jamnut
05-26-2010, 10:16 AM
3.90 would be perfect, work NA & Nitrous.
Beau@SDPC
05-26-2010, 10:27 AM
We have the 3.73s and the 4.10s on hand ready to go. The ring/pinion runs $569.95.
The full install kit runs $254 and just the bearing kit is $55
With the 6spd in either auto or stick form, there really is not a need so much for the 3.90. It was the go to ratio for the 4spd guys, but with them being a thing of the past, 3.73 and 4.10 will probably be the only options for a while.
Beau@SDPC
05-26-2010, 11:06 AM
I think you are mistaken about the 3.73 not being worth the trouble. Just because they are numerically close to each other means nothing.
Looking at final drive ratio of the Auto trans cars, the first gear is 4.03. So that makes final drive stock (auto 3.27) at 13.178. Change that to a 3.73 and you get 15.031. Then lets use the manual trans. First gear is 3.01. So with the 3.45 that makes it 10.384. Then add the 3.73 on there it is 11.22. A good overall change. Not as dramatic, but it works well for either of them. Esp when you factor in effective ratio with tire/rim size as well.
Sorry for the long math lesson, but in reality, any gear change is going to help. Especially for the G8 guys swapping to the Camaro rears that want more boost than stock gears give.
Camaro Z
05-26-2010, 02:26 PM
After going 4.10's in my six-speed I will never have anything less. The change is not nearly as dramatic as some may think. It is very noticable under acceleration, but the highway manners are almost better with 4.10's than with the 3.42's, due to the factory gearing being low. I used to barely use 6th gear anywhere but the interstate. Now I run about ~1700 rpm at 60 mph and around ~2100 rpm at 80 mph, which is really about perfect.
I haven't ridden in or driven a 5th gen, but if you're going to spend the money I would not hesitate to buy 4.10's. I think thats what the car really needs to get that 4,000 lbs on 20" wheels moving.
rouchiemanz28
05-26-2010, 02:45 PM
Havent purchased on yet. Just wanted to know what was the best way to go before I do. Thanks
ss1129
05-26-2010, 03:55 PM
4.10's with stock wheels seems like a no hook-up situation to me. I can barely get mine to hang on with stock gearing and Nittos on the stock rim.
ULTIMATEORANGESS
05-26-2010, 04:07 PM
8-$900 plus install isnt cheap. i hope theres big gains.
