Bad slave cylinder what one should i get
Old 05-26-2010, 04:38 PM
sleeperny's Avatar
Default Bad slave cylinder what one should i get
My car sat for two years while i was building the motor the way it should be done took car to the dyno and after a few pulls clutch started slipping. when i got it home i see fluid leaking from the flywheel housing. i assume it is the slave cylinder but which one should i use and which is good for up to 800 wheel hp.
Old 05-26-2010, 04:47 PM
Red99TA's Avatar
Stock GM slave is the best bet.
Old 05-26-2010, 11:01 PM
elias_799's Avatar
stock gm
