BMR Suspension
05-27-2010, 04:53 PM
BMR Fabrication
Trailing Arms for the 2010 Camaro
Stabilize the caster settings and minimize wheel hop in your 5th Gen Camaro and Pontiac G8 with a set of Trailing Arms from BMR Fabrication. Superior to the factory stamped steel arms, these Trailing Arms are constructed from 1” x 2” rectangular steel and 3/16” CNC laser cut steel plates. The BMR Trailing Arms (TCA027) utilize low friction, Teflon-lined spherical bearings to eliminate bind. Factory trailing arms can cause wheel hop, inconsistent handling, and decreased braking ability under load. Installation time is only 3-4 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com (http://www.bmrfabrication.com), email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrfabrication.com/Press%20Releases/TCA027R_forum.jpg
