Ls1 into a 2007 new body silverado
Old 05-28-2010, 05:59 PM
BLOWN SS/T's Avatar
Default Ls1 into a 2007 new body silverado
I'm wondering if my ls1 from my 98 t/a will work on a 2007 new body silverado pick up truck. And what's needed for the swap? Will the stock harness just plug in?
Old 05-28-2010, 06:36 PM
themachasy's Avatar
Why remove the truck motor?
Old 05-28-2010, 06:42 PM
jay7199's Avatar
thiss
Old 05-28-2010, 07:57 PM
BLOWN SS/T's Avatar
For some power, isn't it common for people to put ls1's in trucks?
Plus it only has a 4.8 engine
Old 05-30-2010, 08:09 AM
themachasy's Avatar
Bet that 4.8 would loooove some boost!
Old 05-30-2010, 08:14 AM
1quickirocz's Avatar
get you a 6oh and be done with it.....
Old 06-01-2010, 05:11 PM
BLOWN SS/T's Avatar
I have an ls3 for the fbody and the ls1 would be a spare engine, what I want to know is if it will work with the new body. Or is there an engine harness that I need or what all is needed or the swap?
Old 06-01-2010, 05:20 PM
Pocket's Avatar
Swap the longblock in and reflash the PCM for the extra cubes. Dont worry about wiring for a 4.8 to 5.7 swap
Old 06-01-2010, 05:36 PM
IH8FORD's Avatar
you will need one of these.
58x-24x-reluctor-wheel-electronic-adapter-module.html
And the crank position sensor is on the front.
4.8's run ok too. My 07 4.8 NNBS ran a 13.70
http://www.youtube.com/watch?v=JTcXMh3Yljc
Old 06-01-2010, 06:41 PM
Pocket's Avatar
D'oh
Missed the 07 part. It'd be GEN IV which requires the necessary changes above along with joining the knock sensor wires into one connector. Its the cam sensor thats moved to the timing cover though
Old 06-01-2010, 11:17 PM
BLOWN SS/T's Avatar
So just about the same things needed for an ls2/ls3 into an fbody, is the harness the same one from leignfilter?
What cam are you running in that truck? Any other mods besides the cam, converter?
Old 06-02-2010, 05:09 AM
IH8FORD's Avatar
Tr220 cam, converter ,headers and 4:10 gears
Old 06-02-2010, 05:23 AM
vetteboy99's Avatar
I don't really see why need for a swap. Just build the 4.8 in it.
Old 06-02-2010, 12:54 PM
deuce4935's Avatar
Swap the crank from the ls1 into the 4.8(use 4.8 reluctor), add a torq-full cam, 3500 stall, headers and an exhaust system and have some fun without wiring headaches.
Old 06-02-2010, 03:58 PM
JonCR96Z's Avatar
That's an idea. Then you'd have a flat top 5.3. Those motors come with good heads (243/799) and good intakes.
Of course, if you're gonna swap the crank, then just bore it and swap the whole rotating assembly over from the LS1. Then you'd have a fresh iron block 5.7.
Or just build a turbo kit for the 4.8.
Old 06-02-2010, 07:26 PM
Mics03Arrival's Avatar
BLOWN SS/T if your serious about the swap, click the link at the top of your screen "PERFORMANCE TRUCKS" and post this in there. You will recieve more than enough information to help you decide.
IMO - dont waste your time or money on that 4.8, they are potent motors but will leave you wanting more. ie. cubes
Old 06-02-2010, 08:33 PM
Pocket's Avatar
If you're going that far, why not just use a 58x reluctor on the alum block LS1 and drop it in as a whole
Old 06-02-2010, 09:56 PM
JonCR96Z's Avatar
Yeah, that's true and loose a little weight to boot.
Quick Reply: Ls1 into a 2007 new body silverado
