ls1 mustang notch first pass
Old 05-29-2010, 11:21 AM
crazygn's Avatar
Default ls1 mustang notch first pass
Here are the mods
1989 notch 3100lbs with me in the car
un open 98 ls1 with 140,000 miles
long tube headers
th400 trans w 4000 stall
3.55 gears
stock ls1 intake
drag tires
it was 84% hum tonight and i ran the car with a full tank of gas. I also ran the car tonight with no o2 sensors at all, locked out so i'am not sure if that was part of the problem
heres what it ran
60- 1.73
330- 5.00
1/8- 7.72@90 mph
1000- 10.08
1/4- 12.08 @114 mph
it was a little hot so i think i might be able to pick up a few there but does this seem right. I think it should 60ft better but not sure if its real rich from the o2's locked out maybe
you think a ls6 intake would help that much ?
Old 05-29-2010, 05:34 PM
blk/slvr02ss's Avatar
U need to get your 60ft time down and less gas and cooler temps and u should runs mid 11's and yes a LS-6 intake will make a difference.
Old 05-30-2010, 12:50 PM
big dave's Avatar
Are you in Md.? Could be coincidence but I saw a white mustang on friday with an ls? motor at capitol raceway but didn't get a chance to see it run.
Old 05-30-2010, 12:59 PM
BennyB's Avatar
an ls6 intake really does help... ALOT!
Old 05-30-2010, 07:58 PM
crazygn's Avatar
Capital raceway on friday, that was me. white with red flames or whatever they are on the hood . I didnt stay real long but i hope to maybe do the ls6 intake if it will help a little then try again
Old 06-03-2010, 04:47 PM
NXPRSS's Avatar
nice numbers! man i would love to have a fox with a ls1 motor in it! such a sleeper!!! good luck with future runs! you def should have that thing in the 11s soon!
Old 06-03-2010, 08:10 PM
crazygn's Avatar
thanks bud, best part is that it sounds like a stock mustang still
Old 06-03-2010, 08:16 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
LS6 is worth an easy tenth and a mph for a bone stock car, total no brainer.
Old 06-03-2010, 08:47 PM
NXPRSS's Avatar
crazygn- how long did it take to build that car??
Old 06-03-2010, 09:31 PM
crazygn's Avatar
not sure how long, it was on and off alot for about a year or two. But if i had the money and bought all the parts i could have built the car in a month or so. Its a real easy build
Old 06-04-2010, 12:14 AM
Ls1Rook's Avatar
Any pics of your car/setup i'm really thinking about doing this.. The coupe is a light *** car.
Old 06-04-2010, 04:30 PM
crazygn's Avatar
let me see if i can find some on here, i'll post some
Old 06-05-2010, 01:45 PM
MASS seller approved
smok'nZ's Avatar
good time also what are you gonna do if that 98 ***** on you? 6.0+n20?
Old 06-05-2010, 04:07 PM
crazygn's Avatar
if it does i have another short block 1999, it has arp mains and rod bolts but spun a rod bearing so i'll prob build that and spray it big time
Old 06-05-2010, 04:16 PM
crazygn's Avatar
some old pic's
Old 06-07-2010, 03:43 PM
2slow2flurry-ous's Avatar
Sick! Hurry up and get a cam! lol.
Old 06-08-2010, 11:39 AM
LS1 BU's Avatar
Nice car. LS6 intake should make 10-15 hp.
Nice to see other conversions.
Old 06-08-2010, 04:15 PM
Nitroused383's Avatar
That 90 degree elbow is not helping at all, similar issue with the GTO's. If you can some how straighten that out it will help as well as a underdrive and ls6 intake. Also get the thing tuned with a wideband. Running no o2 sensors should throw a code and maybe put it into limp mode.
Old 06-08-2010, 04:16 PM
Ph.D. in HUBRIS
custm2500's Avatar
I sure hope you act like an LS1 guy and not a stang *** bag! I have always been a ford guy but since meeting mustang owners at the track and on the street I really don't like anything stang.
Old 06-08-2010, 04:28 PM
crazygn's Avatar
thanks guys
the car was tuned with this same setup other then it had a zo6 cam then and now has the stock 98 cam. The o2 sensors were bad so he just locked em out. I also found my cheap old cone filter was rusted up and packed dirty so i bought a big new K&N filter
I didnt really think about a under drive pulley on here, do they help much.
I dont act crazy like some of those guys man i like all cars if they look good or go fast.
