wanting to put a clutch kit in, what do you recomend?
I have a stock 2000 firebird formula with Ls1 & t6 transmission my clutch is starting to wear out. I'm pretty hard on my car and I am looking to put a clutch kit in it that will handle my abuse and taking it to the drag strip. any recomendations on what clutch kit to buy?? I honestly have no idea
Agreed - it really depends on what power level you expect to be at in the next few years and how often you take it to the track. I just put in a twin disc clutch because I wanted a stock pedal feel and zero chatter. The fact that it holds up to 800 ft-lbs of torque is way more than I'll probably ever need but leaves me room to grow if I ever go with a LOT more power.
I most likely wont be adding a whole lot of power in the next couple years but of course I can't be completely sure, but I want a clutch that will hold up to some serious abuse and last for a good while. also how much difference does the lightweight flywheel make, please explain...srry for my ignorance, I have a very limited amount of experience/knowledge when it comes to transmission components
http://www.diamondclutch.com/
http://www.diamondclutch.com/index.p...d=49&Itemid=56
Right now our Monster Clutches are on sale, check out the prices and packages here:
http://www.monsterclutches.com/gm.html
Call me if you have any questions, 817-750-2000.
Matt
Matt
