Engine bay is done! A few issues with first startup...
I was able to finish up the engine bay this weekend and get ready to fire it up for the first time in nearly 10 months. The good thing is there were no major fuel, oil or coolant leaks anywhere. The bad (1) battery died from sitting so long (2) starter took a dump (3) won't idle on its own in open loop (4) #8 primary glowing because its hot has kinda got me worried.
Moe is going to try to meet me tomorrow or Thursday to see if we can get the tune ironed out. I'm going to do a little more research on why the primary is getting so hot. Any suggestions from you guys would be great. Here's a few pics of the finished product with the custom intake tube and upper radiator support.
as far as the glowing primary is concerned the only thing that i can think of off hand is injector related. LT1 pcms cannot tune individual cylinders so if it is only one primary on one bank than I would check injector pulse with a noid light and if that checked out than perhaps I would consider swapping that injector with another on the same bank and see if the problem follows the injector or stays with the cylinder. I wouldn't run the car very long until you get that panned out, if it is running that lean to get a glowing primary without any real load than you could potentially do some serious damage. Good luck
That is very sharp looking!!! Good Job!!!
I'm curious about that radiator support. What's going on under that panel? What kind of filter are you running? Is the intake pipe steel or aluminum?
Thanks
Thanks
The car has not seen any load yet. Maybe only 5-10 total minutes of idle time in the garage over the last few days.
Thanks! I'm using an LPE C6 filter and an LPE 100mm MAF. The pipe is aluminized steel that was powder coated in "High Gloss Chrome". It's a 1D 60 degree bend from Dr. Gas. The upper support was custom made by a friend with shop outside of Round Rock.
