coil per cylinder?
coil per cylinder?
I am looking into one of the two coil per cylinder conversions out there
The LTCC by baily engineering (which utilizes LS1 coil packs)
http://www.bailey-eng.com/
Or the Delteq which utilizes caddy northstar coil packs
http://www.delteq.com/
Which one is he most reliable unit and easiest to install. Is there any performance advantages of going this route rather than the traditional optispark... who here has done one of these and what is your review on it
You won't see a performance advantage. Both use the optical sensor still, so what are you accomplishing? There are MANY fast cars that still utilize the opti-spark (cap, rotor, sensor and all) with no issues. All it takes is an afternoon to remove it and properly seal it to make sure no moisture gets in (a vented one helps also). I haven't had one problem thus far.
My opti got soaked when I was washing the engine and the car would not fire for a week. But after it dried out it would run fine.... so I figured with the cost of a new opti I can just spend a little bit more and get rid of the part that tends to be the most temperamental on the opti... the cap and rotor
had a buddy use the ltcc and he liked it but still had a problem with his opti after a while then built a 396 and just used the opti, i still use my opti. But if you really want to eliminate the opti due to reliability issues then youre better off completely eliminating it like the 24x kit from eficonnections, bit more expensive but the guys on here say it works like a champ. If my opti takes a crap a few more times once im back from my deployment then i might get rid of it. Just weigh your options as far as total cost and then ask some guys who've done the swap what the real world costs and benefits are from it.
Cap and rotor didn't make it not start so you will still have the same problem when you wash it or get water back down in there. If it runs now leave it alone. The front of my car was under water for an entire day because of a flood we had and I let it sit for a week with the hood open to dry out and it ran fine for 7 more years. and 50k miles before I did an engine build.
I 100% agree if your having to repace it. Thats what I did when I built my 383. Little rtv on my vented so I would not have a problem. It's up to you OP You know the rules of Opti's so if you want to spend the time to replace and seal it up, go for it. If it runs fine again, me I would wait and do it down the road. BUT you never know when that bastard is going to rear it ugly head. lol good luck with it.
Get the MSD cap and rotor which has a vented cap and comes with the hoses. Use a good sealant. I used clear waterproof silicone which worked great and you can also use "The Right Stuff". I use it for a lot of thing. Works great
Is the msd optispark worth the money.... I have heard mixed reviews about them plus I haven't had the best luck with their coils and ignition boxes in the past
I had the delteq for the longest time. No issues with it what-so-ever. I would say its easier. I dont know about performance differences between the two. It is a plug and play unit so, no cutting into wires or anything, just moving some plugs around. That is a plus in case you want to revert back to just the opti for whatever reason later.
I'm not sure if the LTCC is plug and play so, there might be slightly more work putting it in. Delteq comes with a bracket to hold their coil packs on the valve cover and the LTCC you'll have to make/design your own or buy some from someone else.
I don't know from personal experience. Just get a Delco opti with an MSD cap+rotor and you'll be fine. Hell, I have a NAPA re manufactured opti with an msd cap and rotor and i sealed it up and has been running strong for over 4 years. car has seen pretty high RPM's regularly as well
I have the LTCC and if I had to do it all over again i would seriously go with the EFI connections 24x conversion and run the LSx computer. The price would be about the same between the LTCC and the EFI once you factor in the harness and brackets for the coil packs. The EFI conversion pkg eliminates the opti all together. It's the only true opti-elimination option.
with the EFi system you will also be able to use the lsx tuning software so you will be able to find someone to custom tune it easier than trying to locate a lt1 custom tuner.
