Guys with Lokar throttle cables in here please
Old 06-01-2010, 07:24 PM
FASTFATBOY's Avatar
Default Guys with Lokar throttle cables in here please
How did you hook up the pedal end? Did you drill the pedal?
Or
Did you cut the stock cable, slide off the little deal that locks into the pedal and slide it on the Lokar cable?
Old 06-01-2010, 09:26 PM
hashtagBMW
Speed Density's Avatar
It has that peice that slips through the pedal end and then I used the a metal tie to hold it on. That with tension keeps it snug.
Old 06-02-2010, 01:32 AM
Tensec94z's Avatar
Default cable
I just pulled the piece off the stock cable and installed it on the Lokar cable,and yes you have to use fender washers on the firewall.
Old 06-02-2010, 01:56 AM
hashtagBMW
Ill get you a picture tommorow if I remember.
Old 06-02-2010, 07:58 AM
Tapout911's Avatar
I used the red piece off the stock cable and put washers on the firewall. Never had any issues.
Old 06-02-2010, 08:55 AM
FASTFATBOY's Avatar
Originally Posted by tapout911
i used the red piece off the stock cable and put washers on the firewall. Never had any issues.
how close are you to being back together?
Old 06-02-2010, 03:41 PM
quik95lt1's Avatar
Or
yea i just cut the stocker right off the pedal and re-used that little black retainer piece in the pedal....then i just cut off the end of the lokar cable slid it through the retainer and put a barrel end with a set screw on the other side to hold it.....pretty simple.......hope this helps
Old 06-02-2010, 04:01 PM
Tapout911's Avatar
Waiting on AI. Everything else is here. Once they ship my stuff back, its just a few hours work.
Old 06-06-2010, 08:31 AM
FASTFATBOY's Avatar
Well the first time I stepped on the pedal it pulled the cable though the black factory piece.
Guess I will put the clevis end back on.
Quick Reply: Guys with Lokar throttle cables in here please
