c6 z06 tranny overhaul kit
Old 06-01-2010, 09:53 PM
dohcz06's Avatar
Smile c6 z06 tranny overhaul kit
Where can I find an overhaul kit for my c6 z06 t56 tranny ? Is the kit same to the base c6 ?
Thanks DOHC
Old 06-02-2010, 06:47 AM
85MikeTPI's Avatar
Some parts will cross, others are GM only. Depending on your plans, you might be better off working with your local GM parts desk and getting what you need.
Off the top of my head:
GM started using quick engagement synchros and blocker rings on 3-4, in the late model units. The Z06 unit will have larger/different seals in the tailhousing.
Not an exhaustive list.
Old 06-02-2010, 09:01 PM
TDP
TDP's Avatar
Your best bet would be to disassemble the trans, then make a list of parts that need to be replaced. Then order from GM. I don't think you will find any "kits" for this trans
Old 06-02-2010, 10:08 PM
thesource's Avatar
As said above, the later model C6 Z06 unit had some differences inside the unit. I just finished up a unit yesterday that came in with a snapped off mainshaft and busted tailhousing.
