LT1 Problem
LT1 Problem
im having a problem with my car... it will start up an run an drive for about 5 to 6 mins then just shut off out of nowhere.. i sat an held the rpms at 2 grand one time an after about 5 mins it just shut straight off an wont start again for about another 5 mins.. i got a new opti an coil in it so i know its not them causin the problem.. any advice i would love to hear what you's mite think my problem is..
thanks shawn
thanks shawn
also i've had the car hooked up to a scanner checkin all engine vitals an it stalled 3 times hooked up to it an threw no codes ?? im thinkin something is overheatin an shuttin the car off an then when it cools down it fires right back up.. im thinking fuel pump going bad??
Did you have this problem before the new opti or did you install this opti in an attempt to fix this problem?
The reason I ask is because I had a brand new opti do this to me. Once the car warmed up the optical sensor would stop working and the car would just shut off with no codes. If you have access to a scanner (I used a Snap-On MODUS) let the car run until it shuts off on it's own and then check for both high and low resolution signals while cranking. I replaced the optical sensor with one from a known good unit and the problem was solved (until the rotor exploded).
If this problem existed with the old opti as well as the new one then it's unlikely that this is the cause of your problem.
Good luck.
Good luck.
