Oil pressure problem: 50% drop when hot.
Old 06-03-2010, 03:08 PM
black_z's Avatar
Default Oil pressure problem: 50% drop when hot.
Until the car warms up, I have 40 psi of oil pressure at idle, when it gets hot after a drive it is down to ~20 or a touch lower. Under load when cold it rises to ~60, and ~40 when hot. Any ideas on what this may be? Pickup o-ring? Bearings? I am using Mobil 5W-30.
The engine is a 347 with ross forged pistons, stock rods/crank with ARP hardware. I assembled the longblock myself and the pan/pickup/o-ring are new.
Old 06-03-2010, 03:13 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
That problem sounds exactly like the characterisitcs of having issues with the O-ring. When the oil is cold it not thin enough to slip through the o-ring but when hot the oil thins out and finds all leaks possible. I would take a look at the O-ring and see if there are any issues there. Good luck with it!
Old 06-03-2010, 03:19 PM
black_z's Avatar
Thanks John. I assembled all of the oiling system on a stand, lubed the o-ring and was careful, but I guess I was not careful enough. Other o-ring problems I have heard of usually saw lower pressure than this, glad to hear you have seen this before. I will pull it apart and check it out.
Old 06-03-2010, 03:29 PM
Yeah those O-rings are extremely sensitive and just the smallest nick or pinch can cause these kind of issues. I have seen a GM certified tech mess this up 3 times in a row, so its not easy!
Old 06-03-2010, 03:41 PM
bww3588's Avatar
its definately not easy....
let me ask this, did you replace the o-ring? or simply reinstall it? i have seen on numeruos occasions on different engines, where the o ring is reused, it gets torn or nicked upon REMOVAL, then when its installed, even when installed properly, it leaks.
Old 06-03-2010, 04:47 PM
01ssreda4's Avatar
Are you reading the factory gauge? If you are, then install a mechanical gauge before you tear into the engine.
Old 06-03-2010, 04:58 PM
bww3588's Avatar
very good point, the factory gauges have a tendency to flutter as they age.
Old 06-03-2010, 08:08 PM
tg580's Avatar
not trying to jack your thread here but I have a similiar problem. It has only done this a few times though. After a hard run it has dropped from the 50lbs that it is normally at to 20-25 lbs and I can here the motor ticking. Each time it has done it I have shut it down and let it cool for about a half an hour. When I start it back up it is fine. Anyone have any ideas? BTW and sorry for the ignorance what O-ring are you referring to? It did this twice before I modded the motor and once after. I changed the oil pump during the mods.
Old 06-04-2010, 01:39 PM
allngn_c5's Avatar
my engine after sitting overnight will hold 50 psi with a melling hv pump. As the temp comes up to normal its around 40ish. Once oil temps get above 200 degrees, I've seen it get as low as 29 psi at idle. Oil temp was 230 though LOL, had some fun getting her that hot too. When oil temp is 190-209 my pressure is around 29-33. (The numbers are at idle, pressure climbs decent under normal acceleration and comes up with authority under wot.) Ive seen 70 psi before the engine was totally warmed up and when hot still see 50 under wot acceleration. Not sure if you have an oil pump issue or not, but like you have been told its easy to mess up the o ring. Throw a mechanical guage on there and check your readings. If they verify your concerns then you might want to consider checking her out. BTW I run 15w50 with a few qts of 5w30 so we'll call it 12w45 lol. I'm going to run 6 1/2 qts of mobil 1 15w50 when its time to chg due to the hotter weather is here. My car hates cold starts when the temps are down, so I'll go ahead and use mobil 1 5w30 for my fall/early spring oil.
Old 06-04-2010, 01:48 PM
TooLateVTEC's Avatar
To me it sounds like your problem is just from a hot oil temp since you said its after a hard run.
Try switching to a heavier weight oil.
My car gets a little noisey after run hard one time here in the heat/humidity.
Old 06-04-2010, 11:42 PM
black_z's Avatar
Yup it was a new one, new pickup tube too. ****, it is going to be tough to do it in the car if I fucked it up on the stand being careful.
Old 06-05-2010, 01:39 AM
SuperSlow02's Avatar
Mine did it stock...still doing it after a TSP ported pump, goes to about 30psi when hot, but has good pressure at WOT...so im my case...i dont care.
Old 06-05-2010, 07:03 PM
JOHNNY59's Avatar
Default oil pressure
had the same low oil pressure when hot.switched from 5w30 to 10w30 and now my oil pressure doesn't fall below 40lbs when hot.
Old 06-06-2010, 03:18 AM
joecar's Avatar
Before you pull it apart, try M1 0W40 or 10W40 (if you want to stick with M1).
Old 06-06-2010, 10:13 PM
black_z's Avatar
Interesting, I am going to swap to 10W40 conventional and see what happens.
Old 06-06-2010, 10:16 PM
bww3588's Avatar
that makes no sense, 5W30 and 10W30 are the same weight oil except when cold, the 10W is a little thicker.
Old 06-06-2010, 10:55 PM
bagged67camaro's Avatar
i have this prob my motors got a lot of miles though but i switched to 20-50w in the summer has awesome oil pressure all the time
Old 06-09-2010, 01:16 PM
Banned Scammer
434strokergt45r's Avatar
sounds like oring but i put a 383 together one time and a cam bearing walked out of the block and had that issue
Old 06-23-2010, 12:37 PM
STG
STG's Avatar
I'm having exactly this same issue, but on a stock motor with 65k on it. Running 10W30. Is it likely that the engine has developed the o-ring problem over time, or is it probably something else?
In any case, will switching to a thicker oil fix the problem or is it just a bandaid?
Old 06-24-2010, 09:57 AM
02LS1ram's Avatar
I would just buy a new o-ring that costs $4 n replace it for a piece of mind. plus if it doesn't solve the problem u know that is one less thing that it could be
Quick Reply: Oil pressure problem: 50% drop when hot.
