Drag Racing Tech - Trans Cooler - Pics?
MetallicaMatt
06-04-2010, 10:07 AM
Where are you guys mounting your trans cooler?
I bought a Derale from summit with a fan attached, and it looks like I'll have to make some brackets to hold it. Just wondering where you guys found you get the most air
Thanks!
DopeFedZ
06-05-2010, 12:56 AM
http://img.photobucket.com/albums/v225/9secZ28/Formula/DSC03282psd1.jpg
http://img.photobucket.com/albums/v225/9secZ28/Formula/DSC03282psd2.jpg
MetallicaMatt
06-05-2010, 05:37 AM
what made you mount it to the rear?
87Lt1Monte
06-05-2010, 09:21 AM
Im pretty sure the reason people are doing that is for the possiblity of it leaking .. if it leaks way back there, it shouldnt get on your tires..
MetallicaMatt
06-05-2010, 01:24 PM
i just don't see it getting much air back there, even with a fan. I was going to try and mount mine infront of the radiator
LS1SpeedAddict
06-05-2010, 02:59 PM
http://www.easternfbodys.com/forum/picture.php?albumid=35&pictureid=182
Mine works great here, having the fans on really pulls a lot of air over it. This is an old pic but I have it bolted so I can remove it easily. I used metal anchors to do it.
JL ws-6
06-06-2010, 11:54 AM
I was going to buy the same cooler, but mount it up where the stock fuel tank sits. The fan will do it's job I'm sure to cool things off.
4g63tmirage
06-06-2010, 12:40 PM
We were told by Rosler not to run a trans cooler.....
scot
trans2000am
06-07-2010, 05:13 PM
we were told by rosler not to run a trans cooler.....
Scot
huh? Maybe an all out track car that makes one pass then shuts off.
JL ws-6
06-07-2010, 08:04 PM
Rosler said not to run a tranny cooler? That seems a little odd to me. I've never heard anyone be told not to run a cooler before, even all out track cars, etc.
The Guy in MY 99TA
06-07-2010, 09:10 PM
I know a guy who runs a glide w/ the feed line ran out in a loop and right back into the trans. He said his tranny builder said its not needed for an all out race car.
383lt1impala
06-07-2010, 09:22 PM
Maybe not needed but recommend.
MetallicaMatt
06-07-2010, 09:31 PM
I'm going to have to figure out a way and shove it up infront of the radiator for now I think. This winter I'll drop the gas tank for a cell in the trunk, maybe go Jason's route
Quick99TransAm
06-07-2010, 09:34 PM
When i bought my car the bird cover on the bumper was cut out so i used what i had
DMH Fabrication
06-07-2010, 10:24 PM
scot
Sure he didn't say to not run a cheap one? He def. told us to run one and said make sure not to get a cheap one or it will increase the line pressure and not flow correctly.
pro382d
06-07-2010, 10:29 PM
scot
I cant hardly fathom not running a trans cooler, even in my bracket cars i see trans temps up to 240 degrees with a very large cooler with a fan on it. i cant see any benefit what so ever in not running a cooler.
4g63tmirage
06-08-2010, 07:09 PM
He didn't even drill the case for fittings (Dedenbear).
scot
94Z28rag
06-09-2010, 08:12 AM
Makes no sense. These are all but REQUIRED for most race setups (see: transbrake).
JL ws-6
06-09-2010, 12:11 PM
Even the guys I know with rail cars run coolers, and those cars don't get anything near as hot, the load on the tranny is way less (due to low low raceweight)
