New LS1 Owners - Newbie Tech - will a 5.3 throttle body work for 5.7 ?
madmike9396
06-04-2010, 05:17 PM
Just as the title states
Thanks to anyone with info !!!
LivingCanvas
06-04-2010, 05:51 PM
You mean 5.3 truck motor to a 5.7 LS1 right?
Yes it will.
madmike9396
06-05-2010, 12:19 AM
kool thanks
JonCR96Z
06-05-2010, 12:31 AM
I have to assume that you're talking about a drive by cable TB. You will have to swap the throttle cam from your 01 in order to make it work because the truck on is small like the 98-00 TBs.
madmike9396
06-05-2010, 10:48 AM
ohhh thanks for the input ^^^^^^
bagged67camaro
06-06-2010, 11:33 PM
im almosty prsitive the tbs are the same if not someone else will chime in
JonCR96Z
06-07-2010, 12:21 AM
The older truck TBs are the same as a 98-00 f-body TB with the exception of the PCV port uses a longer tube on the truck one (which wouldn't matter). I have one of each right in front me. Since most trucks switched over to the DBW TB in 2000, I've never seen a newer style DBC truck TB. So it may be the same as the 01+ fbody TB as well.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
