Need some opinions...
Old 06-04-2010, 09:22 PM
The Guy in MY 99TA's Avatar
Default Need some opinions...
I'm thinking about ditching my ported fast 90 for a Super Victor w/ 4500 flange and accudfab TB.
I have the car setup w/ a 408, Meaux Stage III LS6s, Solid roller(259/267 .705/702 on a 113+3). Its th400 w/ 2.75 first gear and gunna run a 9" w/ 3.90s and a 29" tire. I'm gunna spray about a 300 shot on the car.
I have the car set up to shift around 7,300 but from what I've been reading the fast isnt gunna cut it for this setup. I REALLY don't want to shift over about 7,500 but I believe this is gunna HAVE TO HAPPEN, especially going to a short runnered carb intake. Though the SV does appear to have a little longer runner than the VJr. I just need to find somebody to do the machine work
I'de love to be able to run something like the cary's intake but I can't afford something like that right now.
BTW the car is somewhat of a max effort street car, I'm getting rid of everything BUT a/c, which sounds dumb... but I'de like to hit up pump gas drags and cruising the coast and stuff and a/c is necessary for this kind of stuff!
Also when I purchased the fast 90 a couple years ago this was the best of the best.
Last edited by The Guy in MY 99TA; 06-06-2010 at 02:22 PM. Reason: changed up a thing or 2
Old 06-04-2010, 10:29 PM
1CAMWNDR's Avatar
Either one will work since you are going to have the 4150 mounting pad milled off and weld on a 4500 pad. With the size of the motor and the 7,500 rpm+ plans the Super might be the best. The Super has larger runners, but is 1 9/16" I think taller. Both can be ported to match your heads. And yes, they will wake your ride up after 6,800 rpms. You will need a cam with more overlap also to really use the single plane design.
Old 06-05-2010, 07:17 AM
yeah your right... I didnt notice that the super victor is not a 4500 series flange... which isnt that big of a deal though. I'm gunna give Allan a call monday morning on the camshaft stuff. IF its absolutely necessary to change the camshaft I'm not gunna do it... at least not right now. IF I have to go that far I'de like to go ahead and change heads to and go with a more aggressive camshaft.
Old 06-07-2010, 02:30 PM
1CAMWNDR's Avatar
Yeah, they are both 4150. The single plane will work with the cam you have and will probably rev out just fine, but to optimize the combination you'd need a single plane cam.
