Window Stuck Down - doesn't seem like motor issue
I rolled my driver side window down today and now it won't roll back up. I've had several motors fail through my history with these cars and this doesn't seem like the typical motor failure. There was no indications of the motor slowing down - it just stopped responding to the window switch.
The only thing I've down is verify the plug on the back of the window switch plate was secure. Before I start tearing into my window, does anyone have an educated guess on what it may be?
Save the manuals!
There are about 3 "typical" ways the motors fail. (that I know of) This is one: (See below with the most frustrating last.)
- Thermal cutoff switch failure.
- Internal corrosion.
- Just died without warning.
This happened to me in a blizzard on the PA turnpike once. You should be thankful its summer! You should keep trying it. Sometimes in this failure mode, it will come up after sitting for a while. If it does, don't put it down until you have a replacement motor! You may not be able to get it up next time.
