where to by mgw shifter
This explains it. I've been looking all over for a better price. I guess I have no choise but to pay full price. I hope it's worth it.
I notice they have an option of 12mm or 16mm (OEM size). Anyone have a preference? Not sure why you'd pick one over the other unless it's **** size (no jokes) or something like that.
Ok since no one chimed in, I called MGW. Yes, the only reason to select the 12mm over the stock 16mm is for **** selection. I was told the OEM size (16mm) is NOT very common for after market *****. You have much more selection available with the 12mm, but you can order the 16mm if you want to use the stock ****. Having a bigger shaft isn't always a better!
ordered mine thise week, only place to get it , hope it solves my 2 to 3 shift probleme ive had for years, tought it was me or my trans. come to find out others have the same probleme and gets worst the more power you make, and i have 457 rwhp.
Placed my order earlier today. I'm going to keep the stock **** for now but i'm going to look for someing a little nicer later. This will be my last stock shifter weekend.
You will love the shifter, it comes with everything you need to install. It will certainly fix your bad 2nd/3rd shift.
Price was extremely good when i bought back in Oct 09, so much so it cost less than 1/2 the price we pay here in NZ.
Was also a bonus to be able to have the angle of the gear shaft changed to the position that suited my R/H drive car before it was sent out.
