Knocking!!!!
Knocking!!!!
Right now under acceleration I get a loud knocking. It soundedlike a tranny mount but I replaced it a few months back. I jacked the car up to check it and everything looked ok and all the bolts were tightened. Is this probably the trans mount or could the u joints be bad?
One more thing, before replacing my carrier, ring and pinion, and all the enternal bearings and seals I took my axles out to replace the outtr bearings, ever since then my ABS inop and brake light are on. I switched to a different size tire but it was months before the lights came on. Thank you forall your help!!!!!
Or is the knocking sound clearly under the car and NOT in the engine compartment?
