TEASER: BLS 93-97 True Bi-Xenon Retrofit --PICS
Thanks to the success and popularity of the BLS 98+ projector headlight setup, I've ventured into a entirely plug-n-play setup for the 93-97 Firebirds.
The kit should be available within the next month!
The kit is 95% complete and will include the following:
- Entirely Plug-N-Play including the wiring - Can easily go back to stock....not sure why you would but you can. No cutting, drilling, tapping, etc.
- True Bi-Xenon projector
- Easy to install
- Same as factory adjustment
Quick Shots
Output - 5000K 35W System
Output at 75' - Need to adjust the passenger side
High Beam
- Easy to install
Quick Shots
High Beam
Parking lamps were from afterthoughtsauto if i recall. The LEDs are from one of my suppliers.
The kit price will be much cheaper than the 98+ Firebird BLS ($875 shipped) however if you want the best and a setup which is literally cake to install, this is it. I wish I could price these for the masses but its simply not in the cards. I only put the best in my car so this is what I ended up with.
Thank you!
