Proform Rockers
Proform Rockers
Okay so im curious to why even tho both these rockers are identicle one costs more? The more expensive one says something about a Clamshell package? Any help is greatly appreciated...
http://www.summitracing.com/parts/PRO-66915/
http://www.summitracing.com/parts/PRO-66915C/
Thanks,
Nick
Thanks,
Nick
The clamshell ones will probably weigh a teensy bit less due to their design. They have a different shape to them. Whether or not you will feel a difference though is debateable. I would get the cheaper ones. I didn't see if it said whether or not they were self-aligning or non-SA.
Pay a little bit more and get these http://www.summitracing.com/parts/CCA-1318-16/
Or go with Crane Golds
i got that same set of proforms when i did my cam swap upon recommendation of a reputable sponsor on here. and granted he has his reasons for it but i wouldn't recommend them. I had them on my car for a short time and the anodizing was already starting to come off and they just looked really cheaply made. the polylocks didn't feel right when i set them.
I ended up with the comp magnum 1418-16. while they are not a full roller they still do the job and are silent!! they are the same price as the proforms and are much better quality.
Yea those are better and lighter. But 7/16" studs which means he will have to also buy new studs.
Scorpions are also popular, lots of people on here run Scorpions and are happy with them. They are priced close to the Proforms too and are within your budget. Harland Sharp also makes some rockers within your budget but I believe they are NSA which means you will also need guide plates.
I wish some of the guys who have been camming their cars for decades would chip in with some of their experience.
Or pay a little bit more and get these: http://www.summitracing.com/parts/CCA-1605-16/
Im just gonna get the scorpion 1.6 3/8 SA and be done with it...even thou i have guide plates...just no extra money to have the heads clearanced for them
What are the benefits of having NSA over SA??
Guys on other Forums (maybe this one too) have posted about their failures and even include photos of the carnage. CompCams doesn't identify a specific RPM above which NSA rockers should always be used but Comp does say they're not recommended for use in any performance application.
NSAs give more reliable valve control. I'm running Scorpions on my engine and my son's as well. I went NSA, 7/16", 1.7s and my son's are 1.7/1.65s. They're priced right, quiet running high quality pieces. $222 at FlatLander Racing.
Jake
My son, Ryan M. Cameron, graduated from West Point on 22 May 2010! He was commissioned as a 2nd Lieutenant and I pinned on his first pair of "Butter Bars" PROUDEST DAY OF MY LIFE!!
There really isn't a point to swap to 1.5rr's your not gaining any lift just slightly less friction.
