What transmission should i go with?
Old 06-08-2010, 11:11 AM
Miguel 69Chevelle's Avatar
Default What transmission should i go with?
I got a LS1 with a t56 but might go with an auto...whats a good transmission to go with?..can any one help?..Thanks
Old 06-08-2010, 12:12 PM
bczee's Avatar
T56 is my choice.. but if your an Auto type of drive.. then convert to it.. the choice is really what you want.
But do your research to see what your getting into..difference in the harness, ECM tune, x-members, Flex/TC vs Flywheel/clutch, Pedals, Throwout Bearing, etc..
also consider the T56 might or will require Trans Tunnel modification.
Old 06-08-2010, 12:14 PM
silverz28camaro's Avatar
A 4l60e with the right parts can hold up very well.
Old 06-08-2010, 02:29 PM
lamdenali's Avatar
4L60E here. but if you go with auto will you sell the T56 ?
Old 06-08-2010, 04:26 PM
bmxmon's Avatar
The autos are way cheaper. You could probably sell your T56 setup for $1500-ish. IMO though I would stick with the t56. Unless your doing a lot of drag racing, manuals are just more fun.
Old 06-09-2010, 11:01 PM
SickF85's Avatar
TH400 here, but would have gone for a 4L65 had my wallet been thicker during my build up. But the 400 is a ripping trans for around town and 1/4 mile runs, but you can;t beat the overdrives for highway cruising.
Old 06-10-2010, 09:56 AM
98SuperchargedLs1's Avatar
built 4l80e here behind a ls2 turbo
Old 06-10-2010, 10:15 AM
Chevy406's Avatar
You have got to make some decisions or share them with us. How much power are you after. How much street driving? What are your goals for the car...
Old 06-10-2010, 03:00 PM
claytonisbob's Avatar
You will definitely have some tunnel modifications to do with a T56. You might be able to get away with using a BFH, but I ended up cutting and re-welding my floorboard to make it fit. Though, I also have the engine sitting pretty far back so it probably took more work. Most auto's will fit with no problems, maybe a little hammer work.
Quick Reply: What transmission should i go with?
