Setting the TPS
Setting the TPS
Hello all I have a some things I need to button up on my 97 383. The engine is miss firing and I need to track it down. I am pulling the plugs and checking the wires tomorrow but I am also going to clean the MAF sensor and I need to check the TPS voltage. I did not have a chance to do this since finishing installing the engine. I am finally moved into the new house and I need to check it and set it up. Is there a tech article on how to do this? If any of you have a write up or know of one, can you post it up for me?
As for the misfire problem I have I am still running on the 100k mile stock ignition modual and coil. The opti is a summit racing opti so I hope thats not it but it is just a random miss at idle that will go away untill about 3k rpms then comes and goes up to the red line. Alot like a bad plug wire or ignition modual on its way out. Is there anyway to test the ignition modual?
thanks for any help
thanks for any help
sounds like the opti,check all plug wires and firing order, buy a haynes manual at autozone for 15bucks and it will show you how to check all ign comp's. did you install summit opti?
I did this last week, but left out slotting the holes. I couldn't find an answer to part of the question, which is: If there is rotary tension on the pass. side TB shaft with the TPS in place, is it a problem? Tension was there before I started the adjustment and after, and I have had no idle issues. I tweaked the position slightly (small TPIS TB screws give a bit of wiggle both ways) to get a perfect .67V at closed throttle and 4.77V wide open. Should it be slotted until there is zero rotary tension on the TPS? Looks like doing so would require positioning the throttle blades too far open to be good for idle... sorry to jack the thread.
I installed the summit opti when I built the engine. I hope to have time to pull the plugs in the morning and see what I have got. I pulled #7 and #4 as a spot check and #7 was dirty but not compleatly fouled and #4 was very clean like new but it had carbon on it as if it had been working fine. I will know more once I get them all out. I hope it's not the opti. I will be removing it if it is. Now I have to go unpack my manuals
