Car is acting up
Old 06-09-2010, 08:22 AM
02pewterform's Avatar
Default Car is acting up
When I drive it feels like the car is missing or bucking a little. I just replaced the plugs and wires, air filter, cleaned maf, changed tranny fluid and diff fluid. I had a scan done and the o2's and injectors are working as they should be. Any help is greatly appreciated. Car is an m6 by the way.
Old 06-09-2010, 08:43 AM
KevinR's Avatar
Have you driven thru a fairly large puddle of water recently?
Old 06-09-2010, 11:17 AM
No I haven't driven through any water recently. I'm beginning to wonder if it could be a drivetrain problem. My rear wines pretty good but I don't know if it could make it do that or not.
Old 06-09-2010, 11:27 AM
Drew24's Avatar
Is it an LSX or LTX? What kind of modifications do you have?
Old 06-09-2010, 01:13 PM
It's an LS1, SLP lid and Magnaflow catback with no cats.
Old 06-09-2010, 10:28 PM
01SuperSport's Avatar
My first guess would be the 02's but I guess not
Old 06-09-2010, 11:02 PM
lt1pwr1's Avatar
Try to get a friends/relatives or someones MAF and swap it in and see if it runs any better. Cleaning it will only help if it is dirty, not if it is actually bad (which is fairly common on these motors).
Does it do it all the time or is it hit or miss? I'm assuming no codes are being thrown?
Old 06-10-2010, 11:15 AM
Drew24's Avatar
Or you can try unplugging the maf and see if there is a change at all.
Old 06-10-2010, 12:42 PM
Marrow SS's Avatar
A few things that you might want to check: fuel pressure regulator and your vacuum lines, a loose or misplaced vacuum line might not throw a code, but can still cause problems
Old 06-10-2010, 04:08 PM
I haven't had time to check anything yet but I was paying more attention to it on my drive to work this morning and it seems like it only does it while maintaining a constant slow speed.
Old 06-10-2010, 04:22 PM
mike171562's Avatar
I had a something like this going on, It turned out to be one of my plugs had a tiny hairline crack in the porcelain
Old 06-10-2010, 05:01 PM
rabbit320's Avatar
what would/should happen if you leave the maf unplugged? ie how to tell if its bad? not to hijack, but... i have same thing going on, also throwing it out here check the pcv system
Old 06-15-2010, 04:43 PM
WS6_LS1's Avatar
Having the same problem. It is fine while cold but once the engine warms up it gets worse. Seems to be most apparent when leaving a stop sign or when at WOT. Just recently replaced my EGR valve thinking that was the problem. New o2 sensors aswell. still same thing. My car is also catless.
Old 06-15-2010, 06:29 PM
fleetmgr's Avatar
You can unplug the MAF, and if it runs better unplugged you likely have your answer...bad MAF. Check your fuel pressure also (41-43 psi), you can rent the gauge most anywhere that rents tools.
