4 channel 12 bolt into 3 channel car?
is the anyway to hook up the abs on a 12 bolt out of my 4 channel ta into a 3 channel 1le z28 without the tcs or would i just be without the rear abs probably will put the 4 channel backing plates back on the ta and take the 3 channel ones of the z28's 10 bolt. so basicly is ther a way to put a sensor above the 12 bolt for a 3 channel setup, or do i need a new housing.
Originally Posted by Damian
You would need some serious rigging to get it to work. 3 channel has a sensor ring inside the housing that trips a sensor on top of the housing.
I'd just put the backing plates back on...Not worth it IMO
Josh
Josh
