i have Questions about the ASA Cam 226/236 .525/.525 110 lsa
This cam has minimal lift and is not too big so I don't think you will have an issues. Do you have aftermarket pistons or rods? how about your heads? If you have aftermarket pistons and milled heads you will have to measure since usually pistons will stick out farther out the hole than stock pistons. Good luck!
ok thanks alot guys i was just worried about the 237 duration, thats why i thought it would hit. i put in a 228/232 .551 lift 112 lsa crane cam in my other car and i had issues so i wanted to avoid them
Thanks
Anthony
Thanks
Anthony
