the tsunami will be here tomorrow!***updated w/ track times!***
i ordered my head and cam combo lastweek and it will be delivered tomorrow.
tsp tsunami 235/240 .654/.609 111 lsa
prc 2.5 ls6 heads
ported ls6 pump
7.425 hardened pushrods
mls gaskets
ls2 timing chain
i should have this all installed by sunday and ill be getting tuned by tj wong early july.
once i get it running i will post a vid. for those of you that havent heard this cam, it sounds meeean! and it makes great power with these heads(at least it does on other set ups ive seen) im pumped, i cant wait for it to run
prc 2.5 ls6 heads
ported ls6 pump
mls gaskets
ls2 timing chain
LS1Tech Premium Sponsor
Have fun with your new parts/power! Let us know if you need any help or advise during install!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I know how you feel. I started working on my car on April 25, and this weekend I am on the last step of building the exhaust. Take your time do it right and enjoy the hard work. My time schedule for work and the amount of stuff I put into the car is what put me off the road for so long.
https://ls1tech.com/forums/dynamomet...o-results.html
these arent my results, im just posting it to show you guys what it can do
Not being an *** and bragging, I'm just telling you what my setup is that layed down more at the wheels. Ordered My Heads/Cam combo from LG Motorsports. IMO just more bang for the buck that's all.
. Stock LS1 Block With Stock Internals
. AFR 205 Milled Heads
. LG Motorsports G5X3 Cam @ 112 LSA
. CompCam 921 Dual Valve Springs
. CompCam Hi-Tech Chrome-Moly Pushrods
. CompCam R Lifters
. ARP Head Bolts
. ASP Underdrive Pulley
. Ported LS6 Oil Pump
. LS2 Heavy Duty Timing Chain
. Ported FAST 90mm Intake Manifold
. Nate Williams 90mm Throttle Body
. Hypertech 160 Degree Thermostat
. Throttle Body Bypass Mod
. QTP Longtube 1 3/4in. Ceramic Coated Headers
. Custom Fabricated Ceramic Coated Off-Road Y-Pipe With Two Electric Cut-Outs
. Borla XR-1 Race Muffler
. Volant Cold Air Intake System
. Mast Motorsports Black Label Aluminum Fuel Rails
. Steel Braided Fuel Lines
. Red Top 30LB Fuel Injectors
. Elite Engineering PCV Oil Catch Can
. Metco Motorsports Valve Cover Breather
. MSD 8.5mm Super Conductor Wires
. NGK TR55 Spark Plugs
. HP Tuners Speed Density Tune
Layed Down 480RWHP and 450RWTQ
. CompCam R Lifters
. ARP Head Bolts
For the OP, let us know your results
