Looking to adapt 90mm LS2 throttle body to LS1 intake manifold
Hey guys is there a way to mount a throttle body part number 12580760 90mm truck throttle body 4 bolt. to a 3 bolt LS1 intake or 3 bolt truck intake? I need to use that throttle body or one electronically compatible to it for swapping a V8 into a 2004 colorado, and I would like to use a cheaper LS1 or truck engine if possible. I wonder if someone makes an adapter to mount a 4 bolt throttle body to a 3 bolt intake??
It cost alot to get a LS2 intake, I am trying to keep the cost a a minamal, basically I want the oposite of this http://cgi.ebay.com/ebaymotors/LS1-L...#ht_2128wt_732
I can get a LS1 and T56 for about 4000-4500 + 90mm throttle body 200 + LS3 E67 computer 300 = 4500-5000 total as opposed to a LS2 and T56 for about 6500- 7500 If I swap to a Ls2 intake than I also need the rails, cross over tube etc.., and that gets pretty pricey I might as well go with a Ls2 to begin with than!
If you modify that plate on eBay you could make it work. Counter sink the 3 holes ls1 patern so a bolt head will sit below the plates surface. You should be able to find some bolts with low profile heads at a hardware store. Then just bolt the ls2 thottle body to it's holes. Thread the holes with a tap so you don't need nuts.
TPIS makes/modifies ls6 intakes to accept 90mm throttle bodies.
http://www.tpis.com/parts/view/39
I beleive you can send them your intake if you have an LS6 already and they modify it for ~350
