Looking at TSP's cam kit...
I want to get a 228R cam. It's got .588 (as most know) and i was wondering if i should get the PAC 1518 valve springs good for .650 lift for extra insurance? Or just stick with the PAC valve springs good for .600 lift?
Thanks,
Jeff
Thanks,
Jeff
whats the expected life on valve springs?? I assumed they would never really fail. Stock ones last 200,000km+ all day long in vehicles and when you get that high, whats another 5-10k?
LS1TECH & Trucks Sponsor
I would expect the 1218s to last around 20-25k miles on that cam, while the 1518s will work for 30-35k. All aftermarket valvesprings wear out over time, especially when used with the larger more aggressive aftermarket cams.
Dual valvesprings will last a lot longer on this cam. I would expect our PRC duals to go at least 45-50k before needing to be changed.
How high are you revving this engine? Will valve train stability be a super crucial issue? I would go with springs rated closer to your lift for higher revving and/or for more stability. I am planning on adding shims to get mine within 0.050 of coil bind. Just adding more stability to the already maxed out stock valvetrain
