Tools & Fabrication - Tools for an engine build
bp944
06-10-2010, 10:15 AM
What tools do I need for an engine build? I'm looking to strip down an engine, clean it and rebuild it. I just want an extensive list so I don't forget anything. If you have any recommendations on companies and all, it is very much welcomed.
fleetmgr
06-10-2010, 09:15 PM
complete set of basic handtools...wrenches, sockets etc.
specialty tools:
ridge reamer
ring groove cleaner
bore brushes
oil sending unit socket
feeler gauges
1-5" outside micrometers
1-5" inside micrometer
dial indicator w/magnetic base
hub puller/installer
taps for every hole size on the block and heads
plastigage
lots of time.
Old Geezer
06-11-2010, 08:32 AM
A pair of torque wrenches. [inch and ft]
A bolt stretch gage.
Ring grinder.
Valve spring compressor.
Piston ring compressor.
You do not use regular taps to clean threaded holes. You use thread cleaner/chaser taps. Not expensive from Summit, etc.
Engine build record sheets.
whtrashferrari
06-11-2010, 01:30 PM
Ring grinder.
they actually rent thread chasers from oriellys now for free!!!!
loan"a"tools!
bp944
06-12-2010, 12:08 AM
I'm assuming everything is in the English system since I hear most stats on the engine being in the english system but is that true?
budhayes3
06-12-2010, 04:42 AM
Could someone list the thread sizes that are necessary for chasing all of the engine bolt holes? :) IIRC the head bolts are not a common size that's in everyone's tap/thread chasing kits
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
