New LS1 Owners - Newbie Tech - 2010 camaro t56 tranny
lazyrichi3
06-10-2010, 12:01 PM
Will a 10 camaro t56 tranny work with the ls1 from an 04 vette that is goin into a s13? do i need any special modification since its not an 98? if i will be usin the sikky kit, will the sikky kit work perfect or i need to mod that as well?
dnt bash at me! im postin in the newbie section :)
-T-56, Found in: 98-02 Camaro, Firebird, GTO*
^^^ i guess that means this tranny is no good right?
battousai
06-10-2010, 01:36 PM
yeah, the T-56 isn't in the 5th gen camaro's.
lazyrichi3
06-10-2010, 01:44 PM
this guy is tellin me his 2010 camaro 6 speed is a t-56... u sure they do not use this tranny?
i guess i'll keep lookin for a 98-02. the 04 vette engine is good tho right?
nvm they confirmed it was not a t 56. sorry.
Nemesis350
06-10-2010, 02:02 PM
The newest camaros and corvettes with manual 6 speeds (as well as other cars) have the TR6060 transmission, which has a list of differences from the T56...
blue98Z
06-10-2010, 02:03 PM
Yeah I think its a T-6060 or something like that. I was told it would work either. Look for the GTO tranny. It's a MN12. Shorter geared and double synchros. If I ever come across one at a good price I'll be swapping one into my Z
lazyrichi3
06-10-2010, 02:04 PM
the guy wanted 1250 for a brand new 2010 camaro tranny im like WOAH so thats what im basically trying to find out.
battousai
someone correct me if i'm wrong, but I believe all the LS engines have the same bolt locations for the trannys, right?
Nemesis350
06-10-2010, 02:17 PM
i want to agree with you on that,... but i'm not sure on the external dimensions/differences of the transmissions themselves. So although it may bolt up, i'm wondering what fitment issues would come up.
I agree with the earlier post on finding an M12 T56 since it's all internal upgrades.
But if someone COULD get a TR6060 for that price, and installation is as simple as a tranny swap... ... well who wouldn't pay $1250 for a 600 hp/ft lbs rated 6 speed? It's takes around $2k to get t56s up to those specs
lazyrichi3
06-10-2010, 02:38 PM
so you sayin i should get the 2010 camaro tranny and bolt it on the ls1? so u sayin it will bolt up but not fit in the "tunnel"?
bww3588
06-10-2010, 02:58 PM
it should bolt up, but you will need the clutch and flywheel from the 2010 as well.
lazyrichi3
06-10-2010, 03:28 PM
i am just scared that it would not bolt right up and does not fit in the "tunnel".
blk/slvr02ss
06-10-2010, 03:49 PM
Well if it dont fit sell it and make some extra money on it but i dont see why it would not fit i would think the only problem might be its a little bigger in diameter.
lazyrichi3
06-10-2010, 04:08 PM
which part of the tranny u think is bigger in diameter? the place thats being bolted on?
tijoe
06-10-2010, 05:16 PM
I received my 2010 Camaro LS3/TR6060 dropout today and took some measurements of the transmission and shifter. (See the attached file)
Enjoy!
blk/slvr02ss
06-10-2010, 05:31 PM
U may have a problem were the shifter bolts up.
00fastta
06-10-2010, 05:54 PM
t56 and t6060 use the same housing...just the t6060 is a stronger version of the t56. They are pretty much the same, but they are not very interchangeable due to the strength, but the t6060 will bolt up to a ls considering that's what its hooked up to in the 2010.
lazyrichi3
06-11-2010, 08:24 AM
yea i was comparin the length, everything seems to be the same except the shifter location. it seems like its further back. blah duno wat to do. go with the 2010 or just get a t56 and save headach...
SWEET98SS
06-11-2010, 10:08 AM
Do a search for TR6060, some one on here put one in their Fbody
lazyrichi3
06-13-2010, 08:15 PM
link? :)
tijoe
06-15-2010, 08:52 AM
Since this appears to be the most current link on the TR6060 Camaro transmission. I figure I'll post the little tid-bit I learned yesterday regarding the shifter assembly.
- The shift lever is offset about a 1/2" from center towards the driver side. I was in the process of positioning the TR6060 transmission in the swap I'm doing and things just weren't lining up. The Camaro aluminum transmission cross member also has an offset, but the mount itself is centered and symmetrical, so I would wager that the 2010 Camaro tunnel is not center either. (Could the complete driveline be offset for balance purposes?)
- More time and money! Now I have to modify the assembly or find and purchase a new assembly that doesn't have an offset!
- I am looking into the MGW short throw shifter assembly. It looks like the offset is put in place on the mounting arms and the shifter assembly appears to be symmetrical.
(One can see the offset in the cast aluminum arms of the shifter carrier.)
