Pontiac GTO 2004-2006 The Modern Goat
2005 Hood Scoop help
Old 06-10-2010, 02:21 PM
01z28Ls1's Avatar
Default 2005 Hood Scoop help
i own a 2004 gto, and recently purchased a 2005 gto hood. The hood did not come with the scoops though. I was wondering if you have to buy the inner part of the scoop and the outer part? I looked it up on GM Parts and it said there were two parts to the scoop so i am guessing you have to have both? I was also wondering if anyone had a spair pair or knew anywher to get them? I have checked ebay but none are on there. Can someone give me some pointers please? Thanks
Old 06-10-2010, 02:40 PM
Buzzmanb12's Avatar
They are two piece but you dont need the inner rubber boot. Check over at LS1gto.com
I have a set of PBM outer scoops if you are interested. Just shoot me a PM.
Buzz
Old 06-13-2010, 10:31 PM
ENUF PWR's Avatar
I have a set i'm in Roswell, GA
e-mail me
smg.customs@gmail.com
Old 06-14-2010, 03:27 PM
Robofuzz's Avatar
The inner rubber plugs basically only keep your engine cleaner. You don't need them. I have mine out because I was told that it helps vent engine heat. But honestly, I don't really see a difference as far as heat dissipation goes.
Old 06-14-2010, 07:57 PM
Roman nj.'s Avatar
saw the outer inserts on ebay yesterday for $50.
Quick Reply: 2005 Hood Scoop help
